MW54 speed sensor help!!!
Ivan
There are two things that can cause this.
1. Transmitter to close to the ECU.
2. Servo’s in a bind. Digital worse.
Not all see this so installation counts.
My fix took care of the two things I wanted.
I wanted to be able to reboot my ECU without rebooting the receiver or work on the jet with ECU off.
I installed a switch and a small Rx battery for the ECU.
Small Rx battery + to the ECU. Switched.
Signal wire from ECU to receiver.
All grounds together.
I made a harness with a switch build in.
Let me know if I could help more
Johnny
disclaimer:
I do R&D electronic work for the DOD –FAA so I thrust my work.
What I am trying to say is do good solder work.
