Battery capacity
Hi,
Due to the above mention problem, decided to use redundant parallel fight packs with two separate switch set up. Currently i have one 2000 mah battery on the roo, can some one tell what are recommended battery capacity if using two batteries in parallel operation (one to batt port the other to extra channel)?Thanks......
Ivan
