MW54 speed sensor help!!!
I believe that the isolation circuit inside the MPX 12 ch receiver is a zener diode circuit. There is a significant voltage drop across the diodes so when you use this feature of that receiver, you must use 6 volt packs. You can, of course, simply use a 4.8 volt pack instead. Been flying this for 1.5 years without a single glitch. Works perfectly.
