RCU Forums - View Single Post - Black Magic VF3 Build Thread
Old 11-14-2007 | 11:57 AM
  #176
handglider's Avatar
handglider
My Feedback: (23)
Default RE: Black Magic VF3 Build Thread
Not sure about that. I have gotten the basic deps from central and then ordered the teflon sheathing from cst - I use the nylon tubes from the deps kit to run my antenna tubes.
Maybe Mike or Arch can pipe in here. But I did a search and I can't find a DEPS style kit from CST - You need the 050 carbon rods, a larger dia rod that they tie into and the fittings.
maybe I am wrong but I don't see a deps style kit from cst - I am sure you could order all the pieces from CST but I've always take the easy but maybe somewhat a little more expensive route and got the kit from central and replaced the nylon sheathing.
there is nothing wrong really with the central kit. you just have to tie down the tubes with kevlar or carpet thread to secure the tubes to the support, you can do a slightly lighter set-up with the bondable sheathing and it's teflon
