RCU Forums - View Single Post - Engine question for TF Cessna 182 kit
Old 11-14-2007 | 08:19 PM
tgaulden
Default RE: Engine question for TF Cessna 182 kit
Here are the specs directly from the web site.
Specs
Type:Gas Electronic Ignition
Displacement:20cc
Bore:32mm
Stroke:25mm
Cylinders:Single
Total Weight:41.6oz with muffler, ignition, and mount
Engine (Only) Weight:33 oz
Crankshaft Threads:8x1.25mm
Benchmark Prop:APC 15 X 6 9500rpm
Prop Range:14 x 6 through 16 x 6
RPM Range:1400 - 10,000
Fuel:Gas Oil mix 32:1
Muffler Type:Compact Welded can (included)
HP:1.7HP @ 8500rpm
Cylinder Type:Nikasil, ring
