ORIGINAL: Hubba092
Brett,
Thanks, mostly all the servos twitch.
Have not had a fly for a few months because it decided to do something itself and ended up in a wall, so have had a break for a while from it.
I have even seen it crash and even though I have killed the power to it, the main blade continues to turn at speed, you have to grab it and pull the power.
Anyway see how it goes, still not to sure on what to do
Cheers
Karl
Definately sounds like a Walkera eletrics problem to me.
Could be a large number of things however check the following at least.
- Loose battery connections on both the TX & RX
- Loose motor connection
- Motor could be on its way out and producing interferance.
- Bad solder joint in the RX (this would be only intermittant though unless its the battery joint)
- Check the aerial on the RX, has it been sliced anywhere close to the RX case?
Anyone care to add to the never ending list of checks for the Walkera gear twitching??
Cheers
Brett
