RCU Forums - View Single Post - OS 160FX is this normal?
Old 11-15-2007 | 10:51 AM
Bax
Default RE: OS 160FX is this normal?
If the engine gets sufficient lubrication and care, the bearings should have a good life. You do need to flood the engine with a good after-run product to protect the bearings against corrosion. A few drops won't do it, you'll need an ounce or so.
