RE: Performance upgrades for brushless super v27??
bashing people about the search function is an ignorant internet thing not an R/C thing.
FREE MODS
The first thing you need to do to the boat is pull it apart.
silicone all the hardware on the transom to solve any leaks you may have.
set the drive strut to 0 degrees (level with the bottom of the boat).
tweak your trim tabs so they are also level with the bottom o fthe boat (this required opening up the hole on the tabs for we to get them even).
scuff the running surface of the boat with some 320-440 grit sand paper (to reduce stiction to the water surface).
remove the battery trays (or atleast the front of them) so you can move the batteries forward to adjust center of gravity.
charge and install your batteries, tape the hatch on with electrical tape (don't forget a small peice for the antenna hole), and have fun.
Enjoy your boat
