RCU Forums - View Single Post - Rhino Jet Engine Time of acceleration/deceleration
Old 11-16-2007 | 02:25 AM
CPS
Default RE: Rhino Jet Engine
Dear Eric:
Thanks for your help again! My friend adjust the parameter under your suggest(acceleration reduced to 12 and deceleration reduced to 8)and the response time of his Rhino has redduced significantly(about 7-9 sec.).I show you present parameter of his Rhino last time of test after adjust the parameter as your suggest:
PW Temp
Idle 078 450 degrees
middle 119 412
max 610 450
Do you thick the engine is normal ?Is the temp too low for this engine,will it result in flame-out?
