RCU Forums - View Single Post - Need Help with Hobbyzone Super Cub
Old 11-17-2007 | 05:17 AM
jetmech05
Default RE: Need Help with Hobbyzone Super Cub
if there isn't a servo reverse switch either on the front, or bottom of the transmitter, then look under the batteries... if no luck then simply reverse the servo arm on the servo so the arm is on the other side..ie if the servo is pointing left now turn the arm over so it points to the right....
