ORIGINAL: jetmech05
if there isn't a servo reverse switch either on the front, or bottom of the transmitter, then look under the batteries... if no luck then simply reverse the servo arm on the servo so the arm is on the other side..ie if the servo is pointing left now turn the arm over so it points to the right....
Tried to change over the servo arms but no room between the servos,the arm fouls on the rudder servo
Thanks anyway
Cheers
