RE: What went wrong with this engine?
Not much to go on. Are any mounting bolts loose, any bolts loose on the engine, carb. and muffler on tight? Does the needle valve seem to easily turned in or out? How long since the last time you flew? Kinks in the fuel feed or vent lines. Did you run it overly lean one time, or was the engine too lean this time?
