RE: prop balencing?
With every prop I buy, I always check the balance. My opinion would be not to just use a prop without checking first. Plastic props do not need sanding or shaving to balance. I like a white or yellow tip, so the tip is very visible when the engine is running. I simply apply more coats of paint to the lighter tip, until I get a balance.
