RCU Forums - View Single Post - Advice on dual EDF setup
Old 11-18-2007 | 10:16 AM
AJ1202
Default RE: Advice on dual EDF setup
airframe if your going with a BL set up you will need to use 1 ESC per motor, now the Q as to the batt is going to be based on your amp load of the 2 motors. it's going to be easier to answer your questions if we know what power your planning on using in the plane.
