RE: Another Mid Star 40
Hi N1EDM,
The only weak spot I can recall with mine was the vertical stab. You'll want to secure it to the horizontal stab with some tri-stock.
If done correctly, the single aileron servo setup will work ok. But building some servo bays into the wings, and using dual aileron servos would be an improvement. Just my preference.
Otherwise the Midstar is fairly sturdy model.
Hope it helps.
