Area Rule?????
Bill;
What about this, be patient.
if i had the cheater through the door, it would be hard to have a inlet duct-- correct??.
what if for take off , let's say. the door is connected to a "door" on the inlet tube. then when the wheel door closes, the "door" on the inlet tube closes also, keeping the inlet clean. then work off of "ram" pressure. while i will still enlarge the inlet itself, to a certain degree. whatcha think??
if you respond, put the dictionary down. i don't think i could go through that again.
thanks
George
