Clutch Liner replacement made easy
I have a simple tool that makes clutch lining
replacement a breeze and most should be able to make
it at home with little expense or tools.
I will use a Raptor clutch for example, for this I
used a 1 1/4 PVC pipe and sliced off a ring between
5/8" and 3/4" long, then I removed aprox. 3/4" from
the circumfrence, sanded the edges and it's done!
You can see it installed in the clutch bell, epoxy
doesn't stick to the PVC either.
Respectfully submitted by;
Andy Tibert
