RE: Aviation Model (SD-Model) 33% YAK-54 --- Build Thread
Yo, P .... did you finish this plane? I have one as well and assembled using the same engine, 3 bladed Mej and a Nova spinner from Airwild. I have Hitec 5985's all around with H9 ProLinks/w ball links, except the rudder where I used a 5955 and the control arm from the kit.
E power is (1) 5200 Fromco with their switch and reg. (1) 2600 Fromco and a switch for the Ign. I replaced the wing tube,main and tail landing gear with Graphtec Carbon Fiber. Every thing else is from the kit.
I sure hope this 3W 70 ate his spinach cuz this pig is 23 lbs 11ozs, that's a long way from the 19lb advertised weight.
What did yours come out at and how does it fly?
Dan
