RCU Forums - View Single Post - Futaba rx--changing crystals
Old 11-19-2007 | 02:06 PM
PipeMajor
Default RE: Futaba rx--changing crystals
ORIGINAL: goirish
I was looking at some ads for futaba rx and a couple of sellers were saying that you could change crystals and use either hi or low band on the futaba fpr127df. I thought that you could only switch crystals within the same band on this model. What is right?
I saw the same ad on a well known auction site. The seller is incorrect. While the R127DF is indeed a dual conversion receiver, you can't use low and high band crystals.
That would be true only of the R168DF receiver. Still, the R127DF was a fine receiver.
