Hi N1EDM,
Hi Bruno, it also behaves better in the air as a tail dragger.
Alex, did the LE come pre-shaped or do we have to carve that one (I'm always worried that I'll screw up the shape).
The LE comes as a square and you need to sand it to shape, I choose to do it at the final sanding because the plane is getting beaten in the process of building, mean while I put some thin CA all over the Leading edge just to harden it so it will be harder to screw it up.
i sanded it to shape at the middle to fit the dwel in.
Now that im thinking about it, I might keep the 8 oz tank, just to have the option to change it into 10 oz.
Alex
