RCU Forums - View Single Post - Geared Speed 400 Turning Backwards
Old 04-02-2003 | 01:58 AM
David Cutler's Avatar
David Cutler
Default Geared Speed 400 Turning Backwards
If the motor was running backwards you should simply reverse the connections to it. It sounds like you shorted the two wires together when you tried this, and stuffed too much current through the controller as a result.
Incidentally, a Rascal might be too much to handle for the first few flights so I would recommend you get the help of an expert at your local club.
Welcome to the hobby, and good luck!
-David C.
