RCU Forums - View Single Post - Wing joining
Thread: Wing joining
Old 11-19-2007 | 11:57 PM
Filipvdm
Default Wing joining
Hi,
I received my LA RACER 40 from The World Models.
When I put the wings together, I can see a little (0.8mm) gap in the middle of the wing.
Can I leave it like that when I glue with epoxy or should I try so sand the surfaces until I have a tied fit?
Also, the covering is overlapping the wing joint surface by 2mm, should I cut this away? I am afraid that doing so, the covering might come loose, but than again, the gap will be even bigger.
Any advise would be welcome.
Filip
