check balance tab wiring
Thanks for your instructionson bulding and wiring A123 packs.
I was wondering if you can check my wiring sequence.
As stated in a earlier post, I am installing a Hyperion 7 pin balance tab onto a 6 cell A123 pack.
The far right black lead from balance tab will be soldered to first negative(the one with main power negative lead)
The second lead (from the right) will be connected to the link between cells 5 and 4
The third lead(from the right) will be connected to the link between cells 2 and 3
The fourth lead(from the right) will be on the bottom of the pack connected to the link between cells 2 and 1
The fifth lead( from the right) will be on the bottom of the pack connected to the link between cells 3 and 4
The sixth lead(next to red) will be on the bottom of the pack connected to the link between cells 5 and 6
And finally the red lead from the balance tab will be connected on top to the cell that has the positive main power lead.
I know its over detailed but I did not want to blow anything up.
Thanks for your patience
