RE: 12Z mixing for flying wings ??
Krysta,
Thanks for the reply. I tried your suggestions, and still have problems. In the original post I did try each of these cases separately. Each was tried with all the others off. So now lets break this up into individual cases and look at each one separately.
For Airplane, 2 aileron flying wing, normal tail type. RUD-AIL feature works as expected, but RUD-ELE feature does not.
Here is what I did:
1 - Re-select Airplane model type, 2 aileron flying wing type, normal tail.
2 - Data reset - All Model Setting (now everything is cleared).
3 - RUD-ELE MIX activate and enter a % for rate A and B
-- No elevator response on either surface to rudder stick inputs.
(this is exactly what I did for RUD-AIL mix and it worked fine)
4 - RUD-ELE MIX “Link” activated.
-- Still no elevator response on either surface to rudder stick inputs.
(Link was not needed for the RUD_AIL mix to work)
So your reply for this question in the above posting does not get it to work ??
For PROG.MIX Throttle to Aileron, and Throttle to Elevator.
Activating the “link” feature as you suggested in the above post did fix the throttle to aileron response. Both ailerons now move with throttle stick input.
However the link feature did NOT help throttle to elevator. Still absolutely no response by either sruface to to throttle stick input.
Here is what I did:
3 - I even verified RUD-AIL and RUD-ELE are both inhibited after the data reset.
4 - PROG.MIX, activate, assign throttle as master and Aileron as slave, set slave Link +, enter a % for rate A and B.
-- All good. Both surfaces respond with aileron movement to throttle stick input.
5 - Then go into that same PROG.MIX and simply change slave assignment from Aileron to Elevator.
-- No response by either surface to throttle stick inputs.
Start over and try it again:
3 - I even verified that RUD-AIL and RUD-ELE are both inhibited after the data reset.
4 - PROG.MIX, activate, assign throttle as master and ELEVATOR as slave, set slave Link +, enter a % for rate A and B.
I think something else is going on here ???
Bryan
