RE: (SPECIAL EDITION)
There isn't a number anyone can give you. You have to find the setting based upon how the engine is being run. Usually, a high-speed needle will wind up between 2 turns out and 1-1/2 turns out from closed, depending upon the fuel and propeller used, and the day's current air temperature and humidity.
