RCU Forums - View Single Post - Is my aerodynamics all wrong?
Old 11-21-2007 | 09:57 AM
dieFluggeister
Default RE: Is my aerodynamics all wrong?
You might want to explain a little about what you had to rebuild to narrow down the possibilities some.
If your rebuild involved the wing, check to make sure it is straight. My first reaction is it sounds as if the AOA may be greater on the left side causing tip stall and loss of aileron control.
