RCU Forums - View Single Post - DO NOT USE AFTER RUN OILS!
Old 11-21-2007 | 01:20 PM
rcdude7
My Feedback: (264)
Default RE: DO NOT USE AFTER RUN OILS!
ORIGINAL: BobMaine
ORIGINAL: rcdude7
ORIGINAL: BobMaine
I think I will continue to use ARO until I get an answer to this question.
What answer would you like?
The implication of the BOLD print used with the exclamation point in the "DO NOT USE..." line on the bottle is more like a "caution" or WARNING" than an advisory. I would have thought that if the statement was advisory in nature it would say something like "After run oils are not needed when using this fuel." No BOLD and no "!" needed. Wouldn't you think so?
Okay, I will just say that over the years I have used Morgans Omega 98% of the time and I have had problems with rust unless I flood the engine with afterrun oil when I put up for the day. This has been especially critical with my fourstroke engines, they really get nasty inside.
I really have'nt been using cool power because a prefer a fuel with a dose of castor in it. Those who do use cool power suggest that the lack of castor leads to even less rust protection between outings.
It's up to you to decide but, I would disregard that suggestion that, "oils are not needed with this fuel" just from my past experience with morgan fuel.
Mike
