RCU Forums - View Single Post - Epoxy cure problem
Old 11-21-2007 | 01:38 PM
Steve Steinbring
Default RE: Epoxy cure problem
Catflyer,
The best solvent for epoxies is probably acetone. Be aware that acetone is an extremely flammable solvent with a flashpoint of -7 degrees F if my memory serves me right DANGEROUS if not handled correctly. You could also use Xylol or Toluol for thinning. Once the solvent flashes out of the mixture curing will occur.
