ORIGINAL: rolyjr
Hi all,
There appears to be two schools of thought relating to antenna positioning: inside the fuz, and outside. Thinking about it, most of the 2x2's I have seen, including photos, the antenna is not evident and presumabley must be inside the fuz. I would appreciate more guidance on this subject from all. I am currently building an Osmose and want to get the plane set up correctly. I will be running a bell-crank with a CH carbon rod, which as I understand it presents it own issues with running the antenna parallel, incl the pull - pull rudder.
Roly.
ps. have conducted a search on RCU, but did not return as much as I hoped, hence I am reviving the subject.
Hi Roly
The antenna can be inside the fuz, no problem at all.
About the MK bell-crank, I really recommend using the CH D.E.P.S., it is far lighter and very accurate, but you should put the servo on its side.
Isaac Najary
