RE: Flameout problem
Bob is right if it's an air bubble causing the flame out you will get a brief smoke trail. No smoke means that your pump shut off. Check all of your electrical connections and solder joints. Run it on the ground and wiggle or tug on the wires. Concentrate on the ECU battery, power wires to the ECU, pump wires, and fuel solenoid wires.
Good luck,
Joe
