ORIGINAL: john agnew
Alex
You might be able to do that by fitting a single turbine and using a straight pipe. I have seen a couple of twins done this way and it works. The taipipes are close enough together so that assymetric thrust is not a problem.It also gives you plenty of room for a fuel tank in the other engine bay.
John
Hi John,
Not in the SU27 there is no room in the fuse to install a single turbine inside, however you can install it outside if you install it inside a fake drop tank.
