RCU Forums - View Single Post - ST 40 Gasoline CDI Ignition
Old 11-22-2007 | 01:18 PM
pe reivers
Default RE: ST 40 Gasoline CDI Ignition
Big Supertigres run methanol fuel with 10% oil, and so do many competition pilots. Since gasoline lubricates better than methanol, I would use 10% with gas and plain bushings. The reason for more oil is, that a gas engine uses less fuel as compared to a methanol burner, and a little extra oil will not hurt, if the carb is tuned right.
