RE: v4 out of control
OK, similar problem guys... the lower gear wobbles when I run at slow rpm, so I guess the inner shaft needs replacement?
Also, one of the swashplate servos went out of line. I turned the tx off and set it at 90 degrees, but everytime I turn on the tx again, it resets itself way off.
HELP!
