RCU Forums - View Single Post - OS 40 LA prop size?
Old 11-23-2007 | 11:42 AM
B.L.E.'s Avatar
B.L.E.
Default RE: OS 40 LA prop size?
ORIGINAL: jaka
Hi!
If you fly at sea level a 11x5 or 11x6 APC is what works best in a high winged trainer.
10x6 is not a good prop size if used on the OS LA. 40 or .46 if you have a trainer in mind.The reason for this is that the LA engines doesn't like to rew that much...but they are good stump pullers and can handle rather large diameter props!
I agree. I had excellent results using APC 11x5 props on the older .40 FP, an older engine that's similar to the .40 LA. This results in excellent climb and reasonable top speed for high wing trainer style aircraft. These engines are like four-strokes and make their best power at lower rpm. Putting a tiny prop on these engines because you think that it is written in stone that an engine has to spin 14,000 to 16,000 rpm just because it's a two stroke leads to the dog reputation of these engines.
