RE: Antenna Position
Hello rolyjr,
I have around 50 flights in my Osmose, with the antenna inside (with tube), and the MK bellcrank using the 3/16 CH carbon tube and steel cables on the rudder, all parallel, no problems or glitches at all, ever.
What ever you decide to go, my only advice is, do a good range check, if it does pass, nothing should go wrong.
The theory is fine but the practice proves also theory is not always accurate, I think I posted pictures where you can see that install.
CPLR and BPLR are using the same set up, I did not invented this set up, they did it first, and proved to be fine in all respects.
Good luck
