RCU Forums - View Single Post - Tips for using Elmers Pro Bond to sheet Lanier Stinger 10 foam wing
Old 03-02-2002 | 03:58 AM
mvigod
Banned
Default Tips for using Elmers Pro Bond to sheet Lanier Stinger 10 foam wing
Ok...up to sheeting my wing on a Lanier Stinger 10 kit I'm working on. Read lots of good stuff all over the map about using Elmers Pro Bond Polyurethane glue to sheet wood to foam.
Any tips or caveats I need to know about to use this stuff and get the "right" result? It says it needs water to cure. Do I need to sponge up the foam wing before applying the glue? Is it best to spread it thing on the wood or the wing using something like a squegee (sp?).
I used to use 3M 77 spray but this stuff seems pretty cool and give you some time to get the alignment right. It also is supposed to penetrate into the foam to give an unbeatable bond.
Geesh...you would think I worked for Elmers?
Any input is appreciated before I tackle this over the weekend!
