Tips for using Elmers Pro Bond to sheet Lanier Stinger 10 foam wing
just get a rag wet and wet the two surphaces so they are damp, let is sit a sec, then spread on the glue with maybe a brush?? stick them together and weight or however the peices into place, the glue will do the rest, and yes, it sticks foam very well!! but, it expands too, can get a little messy untiil you figure out how much you need.
Good luck!!
