RE: GOING IN REVERSE IN CLOCKWISE CIRCLE...HELP???
Does your heli back around the circle or does the tail always point in the same direction while going around. If the tail leads the heli around the circle then you have to trim out the reverse and the rudder directions. If the tail aleays points the same direction around the circle that is toilet bowl effect TBE and is caused by the flybar being bent or not moving properly.
