ORIGINAL: RussWisc
...what is $15 once or twice a year in bearing ....
Russ,
The problem is that often, if the rear bearing has a
metal cage and
it disintegrates, it will be a bit more...
...Bearing, sleeve, piston, ring...
...Need I say more, about why the bearings should last the lifetime of the engine?
And as to the sum you quoted... it is too high.
See the link below:
[link=http://www.mcintoshcentral.com/rc-bearings/catalog/product_info.php?cPath=81_87_97&products_id=646&os Csid=49a5a75ae713c888f2cf8e6ef17ad9b4]The RC-Bearings set for your OS[/link]
