RCU Forums - View Single Post - does battery need Y connection to Rx and engine?
Old 04-04-2003 | 04:13 AM
jimjacobs
Default does battery need Y connection to Rx and engine?
Hey, thanks for the input Sierra. A pod and boom fuselage sounds right. A carbon rod? I know where the aluminum rods and metal wires are at the local shop, do you think they might be near those? Anyway, the reason I am going w/ the pod and boom shape is because I figured it would be a good shape to use to cut down on weight.
I finished this reply and found its longer than I thought it was going to be - sorry for that. Here's a quick reply to the q's you had:
The new wing span is 235 sq. inches. The Troll 35 is a 35 watt motor (I think. I also think its comparable to a 400 type). I have never flown r/c before. I have a Hitec Focus 4 Tx. My motivation to switch to r/c is that I lost a plane and am tired of climbing trees/ using pool cleaning poles.
Here is my saga:
I started out w/ a Guillow's Arrow model (kit 702) that has a polyhedral wing. I put a teedee .020 gas engine on it. I took it to a local field and tossed it downwind (there was a very slight breeze). It took a big left bank as it approached a tall green hedgerow (it was really cool to see 2 white exhaust streams coming off the engine as it banked past the big long hedge). It banked and turned then passed me, then it proceeded to climb and climb, finally going way out of the field area I was in. When it was a few blocks out of the field area, the engine finally died. It started back toward the field and it looked for a second like the wind might carry it back, but it quickly nose dived streets away, never to be seen again.
So I rebuilt the wing and tail section of the Guillow's Arrow from the plans I still had and put in a Hiline Mini-6 (one of the electric motors suggested in the Arrow kit; its a 4.6 to 1 geared shaft on a Micro-4 motor; draws 2 amps at 3 volts giving 1.5 oz of thrust). I put the wing and tail section on a very simple fuselage that I put together. I guess its not really a pod and boom since the boom part is 4 balsa sticks coming out of the back of the pod and tapering together at the end where the tail is. A side view of the pod section w/ the top 2 sticks coming out the back literally looks like:
__._____________________
\_______|
the other 2 balsa sticks come out of the back of the pod and taper up to meet the end of the top 2 sticks (couldn't put that in the drawing since there's no ascii that tapers up that narrow). The nose slants way down at almost the same angle as above, and I put a sq. 1/8" stick of balsa across the front of the fuse (where the period is in the drawing above) to give the wing more lift. The wing attaches with 2 rubber bands that cross over the wing and attach to the fuselage. It is a good slow flier but I think its too small for r/c.
So I looked in the Hiline catalog and saw the Troll-35 which is their 2nd biggest electric engine. I believe it is a 35 watt motor. It draws 8.2 amps at 3 volts producing 2.9oz of thrust at 9300 RPM on a 5.5" prop. It draws 11 amps at 4 volts for 4.1oz of thrust at 10,800 RPM on the same size prop. The package I got came w/ 5 270mAh NiCd's and I plan to use them for both the Rx and Tx. The Tx is a Hitec Focus 4.
I have never flown r/c before but decided I should so that I don't lose any more planes in unknown backyards blocks away. When I was flying the rebuild of the Arrow I made w/ the Mini-6, it ended up in trees requiring climing and the use of long (often tethered together) pool cleaning poles. I wanted to be able to avoid that and an r/c setup seemed like a good idea.
So I knew I needed a bigger plane than my modified Arrow that I have been freeflying with. I got a Guillow's Spirit of St. Louis (kit 807) and put the Troll-35 in it. I went to freefly it and it totally nose dived. I took off the wing (which is 34.5" long, area=190 sq in) and put a pod under it and tapered fuselage w/ the same simple design I used in the modified Arrow. Alas, it nosed again.
So I decided to go w/ a blown up version of the modified Arrow. I xeroxed the Arrow's wing at 1.5 times the actual size and have rebuilt it. Its wingspan is now 53" and it has an area of 235 sq. inches. I am going to keep the same tail section of the original Arrow (modified to have hinged elevator and rudder). The elevator is 11" and has an area of 40 sq. inches. The rudder is about 3" by 3". I plan on putting the engine pretty close to the where the wing is going to be since I'm worried about the nose heavy problem. I hope I have a little wiggle room since I plan on using the same rubber band technology that the Arrow uses to attach the wing to the fuselage.
What I'm wondering is - how long should the boom be? I don't think I'll use the same tapered 4 balsa stick configuration since I figure it might be easier for the servos to hook up to the tail section if the only thing in the way is a boom coming out the middle of the back end of the pod.
Any ideas. All suggestions are welcome. Sorry for such a long post.
