Originally posted by tooly
what servo hitec i should use?
should i use micro on throttle?
I used the new Hitec 5475 (digital) on my ailerons and elevator. I used a Hitec 5645 on the rudder.
As for the throttle I used a small hobbico CS12MG (similar to Hitec HS81MG). The metal gear isn't really needed but I had one laying around.
The servos perform very well and they center A LOT better then the 605s I had in the UCD before.
Hope this helps.............Mark
