RCU Forums - View Single Post - Exceed RC Eagle 50
Old 11-25-2007 | 02:54 PM
  #79
RobBeach
Default RE: Exceed RC Eagle 50
Oh.... so now you tell me... I like your idea much better
My local hobby shop may have them but I found a bunch on the net.
OK.. so now I've gotten to really fiddling around...
The plastic arm that connects directly to the servers, has three holes in it.
Factory has the linkage connected to the center hole. I move it to the inside
hole which makes the heliocopter less sensitive to control, ie easier to fly and
less over correction.
I found it impossible to reinsert the miniature brass connector, so I inserted a paper
clip that fit snugly, using my heat drilling technique as the paper clip was fatter than
the original hole. Bending over the paper clip on the ends so it wouldn't fall out.
You may have to readjust (increase) the pitch of the blades.
For a beginner it makes a big difference, and I like it.
I would suggest ordering a couple of sets of the ball linkages HM-22E-Z-06
keeping your originals intact.
I got this idea from here
http://www.youtube.com/watch?v=s8t-YHE18rs
Im sure some of you already know of this.
I like the modification a lot... at least until I can control the helicopter for aerobatics..
which may be never
Rob
