Need help with first electric setup
I'm currently setting up my first ever electric aircraft and need some help with the battery connections. I have a Deans connector I will be soldering to the ESC and the battery. I know I will want to use the female plug on the battery. My question is about the charging connector for the LiPo. Is it typical to just go ahead and solder this along with the Deans plug and let it hang out from there? Should I consider replacing the plug on the charger with a Deans plug?
Thanks in advance,
