RCU Forums - View Single Post - B-25 Mitchell Threads,Docs,PaintSchemes,Movies&More!!!!---PIN-UPS TOO!
Old 11-25-2007 | 10:42 PM
  #146
dwr
Default RE: B-25 Mitchell Threads,Docs,PaintSchemes,Movies&More!!!!---PIN-UPS TOO!
Here are a couple shots of the fuse. Built six crutch support fixtures for six stations along the fuse then used a guide line to check against the center reference lines I put on the crutch before I took it off the plan. That way I was able to keep the fuse straight as I added
stringers to the bulkheads. It was pretty easy to get out of alignment if not watched closely. DWR
ID:	812094   Click image for larger version
ID:	812095   Click image for larger version
ID:	812096   Click image for larger version
