RE: NItro MIxture, Timing, and Head Shims
If you improve performance by going down in nitro content, then you're running a fuel that the engine's timed for. Nothing more. If you need to run higher nitro, then you may need to reduce the compression a bit, change the plug, and so forth. There is no one, easy answers to this.
