RCU Forums - View Single Post - single-rotor stability sorta solved
Old 11-26-2007 | 08:24 PM
wsdepa
Default RE: single-rotor stability sorta solved
I think that you are barking up the wrong tree. If you want more stability while you are learning use extra collars on the flybar and add electric tape to the blades for weight and impact resistance. Later you will want less weight for better cyclic response.
