RE: Black Magic VF3 Build Thread
Theoretically yes. The V2 that Chris Odom is now flying originally had a gas engine for power and was about 10 1/2 lbs and nothing was done to make it especially light.
If the ZDZ 40 has enough power and is a viable powerplant for pattern use in general, then absolutely it will work....if you can build light and pay attention. No special strengthening should be needed, it's already extremely strong. I would suggest a pro kit with the carbon though, just to make sure.
There is plenty of room to house the engine and pipe. The chin and cowl area is large. just make sure you have adequate cooling and a good soft mount and you should be just fine!
-Mike
