RE: A-10 KITS
Skywalker,
Everything you need to build the plane: the foam cores, all the misc hardware, the balsa sheeting and plywood, and decals. Once assembled, it ends up as fully sheeted so you can finish it with a color scheme of your choice. Can be covered with heat shrink, or painted, or glassed. You provide the power plant, servos, and radio. Mechanical Retracts are optional and can be purchased from them too. It's a quick build technique.
