RCU Forums - View Single Post - Mach .28 engine?
Old 11-27-2007 | 11:03 AM
Reb2973
Default Mach .28 engine?
I finally got my hyper 7 I bought used on ebay, everything works great, Spectrum Dx 2.0 radio, starter box, superbrain charger, 2- 7.2v batteries,glow pug ingnitor all for $300.00 . Everything including the buggy looks mint! Only problem is the Mach.28 engine has me chasing it around with tunning. I get it running good but then the idle starts to stay reved up after about 1/2 tank and the temps are climbing past 270 before I shut it down. I was thinking the lsn was to lean but still didnt help. I pulled the motor out to check for air leaks and seal it up when I noticed i can roll the flywheel over with my finger with little resistance! My O.S. .18tm in my revo is really hard to turn over with one finger. Question is , I guess this motor has hardly no compression left and wondering if this is what is causing the tunning problems and high temps?
The reason I ask is because I have not run a motor till it was dead yet and just trying to learn some of the symtoms that come along with it..
