ORIGINAL: scott36
How hard are the non ringed engines to tuned and keep in a good tune, even in differnt weather conditions. thanks
Do not confuse ABC with some of the non-ring Iron Piston engines that you may encounter. An ABC can be a kind of bear at first few runs. Use a small prop and lean it out. Best racing engine I ever owned, I smoked it on the first run. (Not reccommended)
ABCs, as DR 1 stated, can be slightly damaged if broken in like a ringed engine. OTOH they will serve a long time as a very good sport engine, just don't expect to be out front in a Pylon Race.
Any engine needs consideration at the needle valve in changing wx conditions. For a given needle setting @ 70*, considerably colder air increases the molecules flowing into the same opening, therefore a tad more fuel is needed so open NV a tad. By the same token air at 95* has less molecules flowing into the carb, so some leaning is needed. OTOH if the air supply is humid, then water is replacing the oxygen, therefore additional attention to NV settings may be required. Hot and humid is bad. Cold and dry is good. Same for almost any internal combustion engine.
In glow engines where the temp is generally between 50--75* and humidity stays between 50-75%, the average sport flier will never know the difference without a digital tach.
